stupid newbie (me!) question - difference between DVD+RW and DVD+RW Video box?
Discussion in 'Blu-ray & DVD Players & Recorders' started by djb215, Mar 14, 2006.
  1. djb215
    djb215
    :lease:
    this may be a stupid question to some, but i'm a newbie!
    I said in my first post that my Goodmans won't record onto certain DVD+RW discs, I thought because of the brand.
    I looked on Google, is there any difference in products between:
    DVD+RW discs, and
    DVD+RW Video boxes?
    I said I have a good Sony disc that works, it may be for recording off DVD recorders only, doesn't say anything about Data or photos, whereas the DVD+RW i bought which don't work might be usable for Data and Video.
    Can somebody help me out? Thanks :thumbsup:
  2. Duster
    Duster
    Dec 4, 2002
    421
    UK
    There is no difference in the dvd inside the clear plastic box or dvd case.
    If you find a dvd that works for you, then stick with it.
    It's just down to your recorder which dvds it can burn to or not.
    Good Luck.:)
