Stupid Newbie Limit question - sound settings for CD'S?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Argento, Jan 18, 2003.
  1. Argento
    Argento
    Plays DVD's fine (so far) - but when I put in a CD - and switch my amp to "CD - or prologic" I get a sort of white noise.....
    Any Ideas? I suspect the audio settings need to be changed....
    Thanks folks
    Rich
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    erm are you playing your CDs through the dvd player? if so leave the amp switched to DVD. sorry if that's stating the obvious
  3. Argento
    Argento
    Yep - I know that much!!
    The way my amp is wired, I switch to CD mode - and the 2 x phonos on the back of the dvd go into the cd in on the amp - all preset for the right sound etc....
    No the only new thing to this setup is the limit dvd player.....
    Rich
  4. Kevo
    Kevo
    Aug 23, 2001
    5,465
    Manchester
    +168
    You may need to change the audio setup on the DVD.
    Assuming you don't have DD 5.1 on your amp?
    Set it PCM rather than Digital.
