Stupid HD3 Album ordering question
Discussion in 'Headphones, Earphones & Portable Music' started by aitchjv, Mar 12, 2005.
  1. aitchjv
    aitchjv
    I have had my red HD3 for a week now and almost loaded up all my cds (not that i have that many it just takes time!) but i can't seem to get the albums in the order on the player that i want ie debut/album2/album3....
    I sonic stage they appear in the right order but on the player its always alphabetical - i have even tried to rename the album with numbers but that doesn't work either.
    HELP!
    Thanks in advance.
  2. watchinthewheel
    watchinthewheel
    sorry your stuck on that one. is it really important though? if you want to hear every album by an artist in order simply select each album one after the other, i know you should really be able to change the order but sorry i dont think you can.
