Studio DV Clip
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by steev, Nov 22, 2001.
  1. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    I've just seen this package on Jessops' site. At 50 quid it looks like a cheap way to start editing video from my new camcorder (JVC GRDVL150). Any comments/links to reviews?
    I'm not after anything fancy. I just want to edit down to the good bits with a few titles and possibly insert some pictures from my digital stills camera.
    The plan is to put the results on SVCD to play in a DVD player.
    Steve
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Studio DV (by Pinnacle Software) is well regarded budget software. I think the latest edition is ver. 7 The cost is around £70 or £80
    I don't know if the clip version you quote is an earlier version or a "light" edition.
    The Studio DV editing card (with ver 6 s/w) was being sold off by Dixons at £50. I considered it before choosing an ADS Pyro card with Video Studio 5 software.
    Regards
  3. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    I think Clip has a light/SE version of the software. I asked in my local Jessops and they hadn't heard of it.
    I decided to pay a little extra and ordered Studio DV from Simply as they seemed to have about the best price (no p&p!). I'm looking forward to playing.
    Steve
  4. Guest
    I use several packages and amongst them is studio dv- i recently seen this at 49pounds in dixons- its worth 50quid but i wouldnt pay much more- there is a way of inporting avi video into your dv project if you need help with this reply.
  5. amosdaturk
    amosdaturk
    The review of Tekram DC-1394w card with Videowave 4 based S/w in Decembers What Camcorder? has persuaded me to go for that instead of the Studio DV package. Trouble is I can't find a stockist - any leads out there?
  6. Guest
  7. cal
    cal
    I can't find it either, they must be toying with us!
    Sounds too good to be true!:mad: :mad:
