Studio 8 Make Video Cannot initialise ?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by brado, May 27, 2004.
  1. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    After updating the bios on my ASUS board and my Nvidea graphics card, I now I can get as far as creating a video to tape. I will go no further because it cannot find the DV equipment, which is my camera, connected and switched on to standby. This had worked before I updated to cure another problem
    Next I tried making an AVI file first, which was OK. I then tried to make a tape from that, but with the same end result.
    I am using the latest update to Studio 8 :( :(
    Has anyone any ideas what could be causing this?
  2. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    I discovered I had not updated to 8.12.7 after the reinstall of my 8.3 v.
    Now everything is perfect :clap:
