Stud wall bracket
Discussion in 'Home Cinema Buying & Building' started by mivec, Feb 5, 2009.
  1. mivec
    mivec
    Mar 29, 2004
    62
    I have a Cello 23" in a bedroom and have stud walls. Would a wing arm bracket be OK to fit direct to the wall board?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ideally a swing arm needs to be into the stud work possible without but ideally fix to stud.
  3. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    As 'Horny Dragon' says, you ideally need to fix to a stud. If you can't fix to a stud due to it's location then you can attach a batton or piece of wood to the wall first and attach the bracket to that. Alternatively, if you have solid brick or breezeblock behind the stud wall then you can cut away a small area of the board and mount the bracket directly to the brick. This also means your TV will be completely flush when pushed back.
    Check out our suitable brackets here;
    M-Form - Flexible Brackets
    Hope this helps
    Regards
    Graham
  4. dazzling2865
    dazzling2865
    Nov 12, 2008
    7
