Stud wall advice
Discussion in 'Home Cinema Building DIY' started by zacattack1845, Feb 1, 2014.
  1. zacattack1845
    zacattack1845
    Oct 9, 2012
    43
    Hello,
    Im looking to build a stud wall in front of an existing brick internal wall to house 3 mk iw150's and 2 in wall subs. This also needs to be able to take the weight of my 120inch dnp screen (I believe around 20kg).
    Is there any way this should specifically be done or any specific materials used, a bedroom is behind the wall so ideally it would dampen sound.
    Thanks in advance.
