Stud Fixings
Discussion in 'Home Cinema Building DIY' started by dannyboy23, Nov 4, 2004.
  1. dannyboy23
    dannyboy23
    Hey guys,
    I have dropped some cash on a Panny 6 from AV sales with the tilting wall mount etc etc.
    It is coming before the weekend and I am wondering what fixings I am going to require, screw size etc.. I have checked the plasterboard internal wall and located the studs, I am slightly concerned that the holes on the wall mount wont line up with the studs, are there lots of holes in the mount for this purpose?
    Cheers everyone!
    D
  2. si2k2000
    si2k2000
    Nov 10, 2004
    75
    +4
    Hey I'm in the exact same position as you so would be grateful if anyone has any advice.
  3. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Haven't seen a Panny wall mount but you might be able to drill some additional holes in the mount to get it to line up with the studs.
    John
