stuck on hl2
Discussion in 'PC Gaming & Rigs' started by sc1977, Nov 23, 2004.
  1. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    im on the route canal level (still) and iv hit a brick wall im in a room with a ladder that goes from floor to celing pretty much and there a re loads of flamable barrells about i dont really know where to go from here do i need to push the barrels dow the ladder into the water or what
    please help
    this is probly so obvious but i just cant see the woods cause of the trees!!
    anyone?
    regards
    stu :lease:
  2. DangerMouse!
    DangerMouse!
    Jun 16, 2004
    109
    +3
    This had me stuck for while trying to build barrel ladders but thats not the answer.
    I'm sure if you look hard enough you will get a handle on it, it is a valve game after all.
    Yes it's 80's adventure game crypic clue time!
  3. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    ok sounds interesting ill give it a go
  4. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    DM's dropped a very large hint there!
    I was actually stuck at this stage too, and had to post on a forum for some help... :blush:
  5. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    done it mate cheers
  6. Nivelo
    Nivelo
    Heh, I got stuck on here for quite a while.
    The cool thing about HL2 is that you can try all different things with the physics. I threw a load of barrels into the water below and almost stacked them high enough to hop into the big open pipe :D The barrels shifted and floated away at the last minute though :rolleyes:
    Suffice to say this was not the required solution :laugh: :laugh:
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,149
    This one peed me off to be honest . Just making the thing a little difficult to spot is a bit cheap.
  8. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    Land of the Living, Essex
    +33
    Im stuck trying to find a third battery, anyone wanna help?
  9. pmccurdy
    pmccurdy
    Where would you normally hooked up those types of batteries :D
  10. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,714
    71
    +33
    I thought it was in one of those cars, I must have missed it
  11. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    aka Billy Science - Suni ojna Tas
    +432
    There's actually 4 knocking about :p
  12. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,149
    Why not take a long luxurious soak in the tub and contemplate it.
  13. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    I spent best part of a day trying that!
  14. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    I actually managed to get into the pipe via stacked barrels - took me ages though, and didn't help me much on the other side. Was well annoyed when I saw the easy way of doing it...
