stuck on g/recon.
Discussion in 'General Video Gaming Chat' started by mr chadwick, May 6, 2003.
  1. mr chadwick
    mr chadwick
    hi there,
    im stuck on a mission in campaign mode and its doing my head in.
    its the one were you have protect the tanks (no.9 i think)
    any advice would be very appreciated.thanks in advance.
  2. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    I had problems on this one - all i did was run ahead (using just 1 of the two 3 man squads) of the tanks and kill anything that moved - take a couple of soldiers equiped with anti tank weapons as theres 4/5 enemy tanks around. Play the level a few times and you will see where the enemy are and where the tanks go.
  3. mr chadwick
    mr chadwick
    cheers mate,sounds like good advice.i need to persevere a bit,i just get the hump to quickly!!!
  4. Bonesy
    Bonesy
    Feb 22, 2002
    1,159
    Wiltshire
    +28
    Chad, that is one of the hardest levels.
    YOu need to help the tanks survive, and there are two places they'll get hit..
    1) at the end of the road they head up at the start. you need to leg it up there with a rocket launcher,and take out the two tanks around the corner.
    2) in the 1st square, there are two tanks. you either run like hell in front of the tanks to get their first, or you send a second team through the back route to take them out early.
    (this would be the most elegant way, but I couldn't find out how to do it at the same time as no.1.
    Good luck.
