Quantcast
stuck on farcry
ted26
I am on the dam level and have managed to get to the top of the hill and replenish my stocks then jumped into a jeep :)
Now there is lava everywhere and big mutha trigens kicked my ass :rolleyes:
Seems to be so many of the enemy that its impossible to kill them all without a nuke !
Hows best to get through this mess and how do you take out the big rocket launcher for arm type beasts :confused:
Smurfin
Took me a few tries. Basically, get into the jeep and just power up as high as you can go. Don't stop to take anything or anyone out until you get to the log bridge (where you need to get out of the jeep). Usually enroute you can run one of them over, and use the shotgun on the other one that's close by. Then it's simply a case of getting across the lava via the bridge, then taking everything out at your leisure:)
General Panic
Oh great...it sounds like this game is not gonna get any easier then. It took me most of a day just to get of the dam carrier :(
I think i can only survive this kinda game mentally if there exists a quick save option :)
Panic
Hawklord
Panic
TO SAVE IN GAME JUST BRING UP THE CONSOLE (TILDE KEY) AND TYPE
\save_game
I've only used it on the last level though.
