chipstix24
Hi all,
I'm struggling to find a TV stand/hifi cabinet/unit that fits my requirements. Wondering if anyone here has any ideas...
1) The key thing is that the top surface that my 40" LCD TV [Samsung LE40C530] sits on must be around 800mm. The reason is that otherwise the lower right hand corner of the screen will be obscured by a nearby sofa.
2) Other dimensions are less critical, as long as is it deep enough for my Pioneer VSX-D812 (>400mm)
3) I'm not too worried about number of shelves etc, in fact if it was just an open space inside I would stack
VSX-D812 on the bottom, Sony BDP-S373 player on top of that, then Humax FoxSat HDR, then YouView box and finally on top the KEF 2005 'Egg' centre speaker, in landscape direction. This would all comfortably fit inside the 800mm anyway.
4) Finally, the unit must have doors that allow Infra-Red to pass. Either glass, smoked glass or fabric. If glass, then probably a shelf for the centre channel to sit on otherwise it will block the sound. I have a 7month old daughter that is getting more mobile every day and I want to avoid her stuffing things into the equipment!
Given the above constraints, I am pretty open to the style and materials. Our lounge is fairly modern, but we do have wood furniture (john lewis stowaway range)
Any ideas gratefully received.
If I can't find anything off-the-shelf, then a reasonable value made-to-measure recommendation could be useful. I am in Sussex, but further afield could work.
Thanks, Chipstix.
Thanks, Chipstix.
