Struggling to achieve720p
Discussion in 'Desktop & Laptop Computers Forum' started by Ken, Dec 23, 2003.
  1. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    I am trying to run 1280 x 720 on a Sharp Z9000 with an Ati 9600 card but it refuses to take it; I have used powerstrip to load the resolution but no matter what resolution I try it seems to squash within a 4:3 frame.
    Am I doing something completely stupid. I just got the projector and am dying of frustration.
    Ken
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,142
    Surrey. UK.
    +1,953
    The 9600 has this as a native resolution, so you could try it without Powerstrip to see if that's the culprit.
    I'm wondering if you have to tell the pj to take a 'native' signal from a PC rather than try to scale it perhaps. It's probably a menu option somewhere on the pj.
    Gary.
  3. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    Well I got it working. I had to use powerstrip to set the resolution; which was all squashed up; then in the menu the 1280 x 720 option was now available. Success.
    Now does anyone know how to get 1280 x 720 from the 9600 without using powerstrip.
    Ken
  4. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    According to thre Ati spec for the card you can't. So I will continue to use powerstrip.
    ken
  5. Kramer
    Kramer
    Once the resolution has been accepted (written to the registry), you should be able to uninstall Powerstrip.
    It's handy for "hotkey" resoluion changes though.
    1280x720 is a pretty "standard" res these days so would imagine it's supported by the ATI.
    :smoke:
  6. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    Thanks Kramer, I will try that.
    Ken
  7. Ken
    Ken
    Dec 15, 2000
    360
    Stoke-on-Trent
    Resolution sticks nicely, thanks for your help.
    Ken
