Strong SRT-4375 receiver?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by aekostas, May 5, 2007.
  1. aekostas
    aekostas
    Jan 2, 2006
    1,263
    48
    +52
    In my quest for a cheap receiver capable of feeding a 36V motor, I came across the Strong SRT-4375. Would you have any input re reliability, quality etc? Do you know if it outputs RGB? Does it have more than one scarts or perhaps an RGB scart and and S-Video and RCA combination?
    TIA! :thumbsup:
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
  3. metroman2
    metroman2
    Apr 14, 2005
    130
    +14
    I've had two of these and yes they are pretty old now. The digital tuner went on both of them but the positioner was fine.
    I'm currently using a Tecnomate DAPCI 5000 and it's been fine for at least 2 years that I can say, time goes by so fast;
  4. aekostas
    aekostas
    Jan 2, 2006
    1,263
    48
    +52
    Thanks. I guess it willl have to be exceptionally cheap to be worth it; there will be zero support and the installer may struggle. Any crucial technological advances that it lacks?
  5. aekostas
    aekostas
    Jan 2, 2006
    1,263
    48
    +52
    45 quid all in. ;) I thought it was worth a punt :thumbsup:
