Stretching video
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dsw182, Jul 19, 2005.
  1. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    Not sure if this is the correct forum, but seemed most appropriate...
    I have some video files which are 'squashed up' - 2.35:1 clips in 4:3 ratio.
    Is there a program which can stretch them out, back to how they should be? Nothing I've tried so far has been able to resize them in the way I require.
    Thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,354
    Rainham Essex
    +2,441
    AFAIK most editing software should do this. When you set up the project just tell it that the video is widescreen and it should stretch it back to the 16:9 format rather than squashed 4:3.
    Mark.
  3. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    I can get it into 16:9, but not into 2.35:1
  4. Kevo
    Kevo
    Aug 23, 2001
    5,401
    Manchester
    +149
    Use 16:9 and have borders top an bottom
