Question Streaming tv with a black border around the tv
Gr8tylor
Through any addon with my minix neo x8h plus there's a black border around the edge of the screen. I'm sure it's something in my settings but I can't figure it out. When I change from xbmc/kodi to the Internet browser to watch tv through streamlive.to there's no border. It's only when I watch shows, not on any addons or menus?
Gr8tylor
The black border is approximately 1" and almost goes all the way to the edge but there's a 1mm thin strip where I can see the tv broadcast
JonMace
In Kodi
System / system
Video output Tab
Video calibration - you should have a sort of inverted L in the top left use the arrow keys to make it go just off screen - press enter - do the same to the bottom right - exit out.
You should be done
Gr8tylor
Here's what I'm talking about
Jamie
Go back to the calibration and set it back to 100% instead of this option look for setting in your TVs menu for fit to screen or similar option (just scan)
JonMace
How old is the matererial and what quality is it?
Try watching something that is HD and see if you have the same problem
Gr8tylor
It was all in the settings, the calibration where you align the corners, I think after I aligned it before it didn't save for some odd reason. Thanks again
