Streaming TV sound to hearing aids.
cheddarcaveman
My television is a Samsung UE50TU7100KXXU SMART TV
Everything I have tried to stream the TV sound to either my hearing aids or Bluetooth ear buds has the sound OUT OF SYNC!
I'm buying a "ReSound UniteTM TV Streamer 2 by GN Resound" work with this set up and more importantly will the sound be IN SYNC with the television picture?
I had the same problems with five sound bars I tried!!
JayCee
Your TV should have a sound delay setting in it's sound settings menu.
Have you tried altering it?
JayCee
Look under “Expert settings” if that is available in the sound settings.
cheddarcaveman
RIGHT!
I have received the ReSound TV streamer. It's connected to the TV via the digital (optical) output and works a treat, really clear, in sync, sound. HOWEVER on the TV I have to select the digital output in the sound menu and when I do that the TV speakers are turned OFF, nobody else can hear the TV.
Going into the TV menu, General - Accessibility - the "Multi Output Audio" option is grey out, not available!!
How can I get sound from both - buy a new TV???
cheddarcaveman
SORTED! I have to access the TV streamer in my hearing aid App on my iPhone. There is a menu along the top (which wasn't there before I installed the streamer) and when I select TV Streamer the audio comes through, very clear and in sync!
Thanks guys!
