streaming ts films from external usb hd
Discussion in 'Xbox Forums' started by spadge, Mar 19, 2006.
  1. spadge
    spadge
    ive got 1080i ts films streaming from my media center pc with a wired connection does anyone know if i could play these from an external hard drive through the pc.its a usb connection but with the high data transfers i thought it might chug cheers spadge
  2. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
    you can add a folder to my videos on the media centre and point this to the usb drive
    selct the my videos menu item press info and you should see add folders
  3. JinBoy
    JinBoy
    Dec 29, 2005
    29
    Slough
    +3
    This is exactly what I do, it works just fine. The only problem i ever encounter though is when you try to fast forward a few scenes. This can be a bit sluggish via the usb hard drive and can sometimes cause a network congestion error message. But it does recover after a few seconds.
