TB Rich
How are you matching levels in this scenario?It wasn't anything to do with the output levels, they were matched to ear and switched between the two playing the same tracks,
No discernible difference in volume between the Sony and Toshiba when switching over between optical inputs on amp.How are you matching levels in this scenario?
This subject has been discussed in great depth on other forums, many other users also say there are differences (mainly in soundstaging, timing & musicality) so it's not just me.
I think this is the age old argument with video also. If it's 0's and 1's is it either snakeoil by those wanting to sell or simply the plasebo effect. Digital is digital. As someone who takes photographs for a living it makes no difference what SD card I use, what cable I use to transfer the data over - it's just 0's and 1's
