Streaming to Xbox 360 how
Discussion in 'Xbox Forums' started by delboyuk2005uk, May 7, 2007.
  1. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    I have looked and cant find anything!
    Can somebody tell me all the software I need to be able to stream files to my xbox 360 please?
    any links will be useful on how to set it all up as well.
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    Are you trying to stream from a windows xp pc to your xbox 360 via wireless network
  3. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
  4. clarky78
    clarky78
    Nov 8, 2004
    1,918
    Helsinki, Finland
    +43
    It's fully covered in the Sticky at the top of the forum.
    Basically you just need windows media player 11. A wireless gaming router or Xbox360 gaming adapter or a wired conection via your router.
  5. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    I want to be able to watch hd files like the lost ones on torrent sites?
    i will be using a wireless connection.
  6. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    yes i am
  7. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    Torrents are bad! :nono: You did mean to say that you want to stream .avi/xvid files then you will need tversity :smashin:
  8. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    there are many legit HD trailers and short movies etc in HD available totally legitimately through torrents.
    Anyone seen that short movie about the sniper? fantastic! but cant think what its called!
  9. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    ok .avi divx files then lol, am gonna download TVersity, what do i do next
  10. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    search the forum for TVersity, its been covered loads and people will only repeat what has already been said.
  11. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    right i have downloaded tversity and it is now connected to my 360. when i try and play divx now still sys file not supported what else od i need?
  12. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    What sniper in Lost ? :eek:
    I understand that a torrent is a method of sharing files. Yes plenty of valid torrents around, Sky have rolled out a torrent feature and BBC are looking into it. As the post did say 'Lost in HD' thats why I posted 'torrents are bad' :nono: Well, whatever you do in your own home is up to you. ;)
  13. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    Does the video play in windows media player? If not then you'll need to download the right codec. I have FFDShow installed, works with just about any video format.
  14. mremulator
    mremulator
    Sep 19, 2005
    1,090
    Surrey
    +67
    For HD .TS files you only need to install HDTVPump on your PC and there is no need to transcode.
  15. avinitski
    avinitski
    Apr 22, 2005
    3,319
    +216
    come on anyone know the short movie i mean? was about 9 mins long about a sniper?
  16. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,159
    Bristol
    +9,898
    Have you tried searching the forum? because I am sure tversity has been posted about many times and it would be far quicker to search through old threads instead of waiting for someone here to post old info.
  17. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    managed to stream divx files.
    now for hd files will i need 360 hd drive play these or can iplay them on normal 360 drive.
    also if wmv files only files xbox 360 can recognise whats the best converting software to wmv for the 360
  18. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,159
    Bristol
    +9,898
    The HD-DVD drive is for HD-DVD's only, you dont need it to stream or playback HD files.
    Also, why would you want to convert files to WMV when you can stream Divx files already?
  19. clarky78
    clarky78
    Nov 8, 2004
    1,918
    Helsinki, Finland
    +43
    Use a piece of freeware called Encode360, takes time to encode but works fine for me.
