streaming over a home LAN
Discussion in 'Desktop & Laptop Computers Forum' started by owain_thomas, Jun 29, 2003.
  1. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    I've just got a home network set up, but I'm having difficulty playing media files over it. I have my music drive shared over the network and can see it on the remote computer but when I try to play it with WMP9 it comes up with an error message saying that it can't access the file. Do I have to do anything else to allow the files to be played across the network, or should it just work once the drive has been shared?
    TIA
    Owain
  2. TEK
    TEK
    It should work if the share has permissions set accordingly. You could also mount the share locally and set it to connect at startup. This should sort out any permission issues when the client starts up rather than when it first makes a call to the share from MP
  3. frog
    frog
    May 1, 2003
    63
    Is your lan wired or wireless ? I have both, but streaming over wireless lan (11mb) is useless, WMP9 keeps saying that the connection has been lost or something like that.
  4. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    This is bizarre, I've found that things work one way but not the other:
    PC1 can play PC2's shared files over the LAN no problem.
    PC2 can access the directories on PC1 but not actually play the files. It's set up to map the drive on startup but no joy on actually playing the file. If it's just a text file or something it opens, but media player doesn't seem to want to play.
    Any suggestions?
    Owain
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    It could by a media player digital rights issue.
  6. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    what os are you using
    boogie man
  7. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    cheers for the replies, how can I find out about whether its a DRM issue?
    I'm using XP pro.
    Owain
