Streaming movies ?
Discussion in 'Playstation Forums' started by iwearahalo, Feb 9, 2009.
  1. iwearahalo
    iwearahalo
    Aug 14, 2008
    148
    19
    Hi there , I am connected to my pc and get all music and photos but what to I need to be able to stream films from my pc ? I keep seing tversity ? What is all about , is it easy to do , I mean do I just play the movie and it will then goto my ps3 ?
    Many Thanks
  2. phairplay
    phairplay
    Mar 19, 2007
    5,183
    lurking in you wardrobe
    +964
  3. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    Presumably you're using Windows Media Player to stream the rest of your files, so use WMP to stream your movies in exactly the same way. Share the folder out, make sure they're named .mpg not .vob and voila.
    It all depends on the format of your movies really.
  4. iwearahalo
    iwearahalo
    Aug 14, 2008
    148
    19
    What I want to do is watch movies from say tvshack , I have read that tversity also downloads if you do not notify not to and I am worried where I know nothing about pc's I will not be able to turn this off and end up with rubbish on my pc ?
  5. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    Don't install TVersity then :) It used to automatically setup some streaming feeds, not sure if it does that still, don't think it does.
    What's tvshack ?
  6. phairplay
    phairplay
    Mar 19, 2007
    5,183
    +964
    i've been using tversity for about 5months an swear by it really easy to use and it work brilliant wirelessly. it has never downloaded anything to my laptop
  7. Tall_Paul
    Tall_Paul
    Dec 3, 2005
    8,567
    Kent
    +2,172
    You might want to edit the thread title, might attract the wrong crowd ;) :D
  8. phairplay
    phairplay
    Mar 19, 2007
    5,183
    +964
    haha just put my glasses on and saw what you mean lol :rotfl:
  9. iwearahalo
    iwearahalo
    Aug 14, 2008
    148
    19
    So if I download it , do I just set as default or do I not accept everything ?
  10. iwearahalo
    iwearahalo
    Aug 14, 2008
    148
    19
    Ha ha I have seen that myself :oops:
  11. iwearahalo
    iwearahalo
    Aug 14, 2008
    148
    19
    Cant find the edit on the title so it will just have to stay ! My girlfriend is laughing her head off to this , lucky I told her and she did not find out any other way :) Also a fair few quick replies to this :)
  12. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    I don't know why you want to download and install TVersity when you're already streaming with other software, presumably WMP ?
    You're better off installing the newer PMS media server if you want to do that, it's much more efficient at transcoding on the fly, if that's what you need to do, but we don't know what files you want to stream...
  13. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    You mentioned the site 'TVShack' I'm not familiar with this service but it appears to be a TV streaming website?
    Your options really are to either try playing the streams on this website directly through the PS3 web browser (may or may not work)
    or
    Add the Streaming feed for this site into the Web streams/RSS config file of a streaming app like TVersity or PMS media server running on your PC. the support forums for the individual apps mentioned are probably the best place to advise on getting this feed working in a particular app.
  14. iwearahalo
    iwearahalo
    Aug 14, 2008
    148
    19
    I have not got a clue myself , I can see the files/music on my ps3 , but how do I see the say a film from tv shack ? I have not got a clue how to see this where do I go on the xmb ? I do have wmp11 .
    Many Thanks
  15. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    I refer you back to my previous answer above.
