Streaming Media
Discussion in 'Microsoft Windows' started by cmclean, Feb 10, 2009.
  1. cmclean
    cmclean
    May 29, 2003
    1,011
    +117
    Anyone in here streaming media from their WHS to the following....
    Xbox 360
    PS3
    XBMC
    If so could you tell me what file type you are ripping your SD DVD and Blu Ray movies to please and also how you are able to stream them to each of the devices.
    I cannot seem to find a conclusive solution to rip both movie types to be stored in a single file format on my WHS that can be played on all devices. Yes I know I can't play the HD movies on my XBMC without special cables and stuff so just wanting to play the SD DVDs on that.
  2. graham.myers
    graham.myers
    Mar 11, 2003
    6,228
    Leeds
    +931
    I'm streaming DVD .ISOs from my whs to an AppleTV running XBMC. Runs fine I using it for TV series so get the full menu and not encountered any problems.
    Have AVI's and a couple of MKVs but not sent them to XBMC so dont know if they work as I'm happy with the .ISOs. Also not tried bluray yet
    I also stream to a PCH-100 with no issues.
  3. Synchro
    Synchro
    Nov 14, 2004
    6,004
    Chester
    +1,538
    Tried streaming a Blu-ray ISO the other day :thumbsdow
    Need to upgrade my network a little :smashin:
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Ripping SD-DVD to single vob file and Bluray to MKV. not fussed about menu's etc.. just the main video and 5.1 audio stream.
    Stream to my PS3 using PS3 Media Server
    appreicate PS3 doesn't playback MKV but I'm kinda hoping it will in the near future :rolleyes:
  5. sparkygeezer
    sparkygeezer
    Nov 11, 2007
    4,028
    Bedford
    +135
    MPG files seem work ok for both XBOX360 & XBMC not sure about PS3 but I can not why not.
  6. cerebros
    cerebros
    Dec 27, 2002
    1,366
    48
    Leicester
    +43
    What software are people using to rip their DVD's/BD's?
    I've looked into this in the past (for DVD's) but ended up banging my head against a brick wall as software either didn't work, codecs wouldn't install, or didn't preserve the 5.1 audio.
    Also, are you re-encoding to a more efficient format or just taking the data as is and dumping it into a different container file format
  7. cmclean
    cmclean
    May 29, 2003
    1,011
    +117
    Isn't such a straightforward question to answer because it really depends on what program your planning to use to stream as that may only support certain video formats and also what your player is for example Xbox, PS3, etc?
    However, to try to answer your question I use AnyDVD HD which will rip DVD and Blu Ray without any issues. I rip DVD's as .iso files store them on my WHS and play them using XBMC mostly. They will also play fine via PS3 Media Server to my PS3
    I'm still trying to get a solid solution for Blu Ray playback so I currently rip Blu Ray movies to .iso file too so that I have a complete rip of the disc and then have tried converting to .m2ts, etc
    The downside to my method if I'm honest is that movies take up a huge amount of space but I'm ok with it cos hard disks are so cheap these days and my WHS has tons of capacity.
    On the positive side in relation to your audio issues this will preserve all the audio formats and allow me to choose which audio track even manually using XBMC.
    But as I said at the start it depends what your using to stream and what to as your codec issues will relate more to those than what software you use to rip
    Hope this helps
  8. cerebros
    cerebros
    Dec 27, 2002
    1,366
    48
    Leicester
    +43
    I'm currently looking at using the built-in media playing capabilities of TVs to play things back - probably the facilities in the current Samsung line as they seem to support quite a wide range of formats.
    Obviously if I went this way just ripping ISOs isn't going to be any good as the set won't recognise them - ideally it needs to be into one of the formats the set supports (see here about halfway down the page for the formats supported by the Samsung I'm looking at).
    I've also got to hope I can find a format that the set will be able to output the 5.1 audio from via its optical output.
