Streaming HD Video – Help with Routers
Discussion in 'Networking & NAS' started by craige4u, Jan 10, 2012.
  1. craige4u
    craige4u
    Mar 18, 2007
    56
    I want to stream 720/1080P movies (Files around 10GB) frm my desktop to my TV and tablet via wifi.
    Now which of the below shortlisted routers can do so without any Lag or Freezes. I live in a 750 Sq ft. Apartment.
    Belkin: N600/N750 DB
    Linksys (Cisco): E3200/E4200
    Links:
    Compare Belkin Routers
    Linksys E-Series Product Specs
    Thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,497
    Rainham Essex
    +2,506
    Streaming HD video over WiFi is very unlikely to work without issues. Although Wireless N is theoretically fast enough for HD you need a very good signal with no interference from other networks in your area, or any other devices. Therefore very few people get it working well.
    Save yourself all the headaches and go for a wired solution or settle for SD streaming.
    Mark.
  3. rs6mra
    rs6mra
    Dec 13, 2011
    650
    +64
    Consider the D-Link DIR-645. Reviews on this have been really good.....
  4. rs6mra
    rs6mra
    Dec 13, 2011
    650
    +64
    I however do agree with MarkE19's point. Go wired whenever you can
  5. craige4u
    craige4u
    Mar 18, 2007
    56
    I am looking for answers (plz suggest frm the selected models as these are the one's available in my country)
  6. themediaman
    themediaman
    Nov 17, 2010
    2,017
    Glasgow
    +171
    As far as I am aware the wireless bandwidth will only just support 720p streaming, so a few MB/s, maybe 5 max............
    1080p stuff you will have no chance really............so the tablet should be kept for 720p stuff..........
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,497
    Rainham Essex
    +2,506
    If you currently have a wireless router and can't get reliable streaming with that one then buying another router is unlikely to fix the problem. Interference etc from other devices wont be cured with a new router.
    Mark.
  8. coolamasta
    coolamasta
    Nov 22, 2011
    203
    Brizzol
    +30
    You could look at power line converters, get a decent set of 300mb/s ones and you'll be sorted, I use a cheap unbranded set from eBuyer to go from my house to my garage so I can have an internet connection and to stream music when I'm working down there.
    I went for this option as it was too hard to try and lay a cable from the house to the garage plus I only have about a 10% WiFi signal coverage even with a Netgear RangeMax N access point which drops in and out badly and can barely stream an MP3 without jittering!
    When I first set up the power line plugs just for a test I streamed some 720p and 1080p content from 4-10gb in size and they played back without jumping/jittering so I was impressed although they will never be used for this.
  9. craige4u
    craige4u
    Mar 18, 2007
    56
    Thx for all your replies,
    I have decide to go with the wired connection route, and bought a cheap N300 MBPS Router for surfing and stuff on my tablet.
    Anyways, i would still like to experiment on hows streaming goes on this router - So wht software you ppl suggest shall i be using for it...
  10. themediaman
    themediaman
    Nov 17, 2010
    2,017
    Glasgow
    +171
    you will need a media server program on your PC, windows has its own, but there are better ones out there like twonky and servio...........
    your TV will also need to be able to see those servers and access the files, otherwise a networked media player will be needed..........
  11. virgopunk
    virgopunk
    Jan 16, 2009
    71
    London
    +5
    Just another consideration; I'd move your media files off your PC onto a stand alone network drive. PC's can stream but are fiddly and don't like connecting with other devices very nicely. CODECS are an annoying pain particularly if you're going down the HD route i.e. mkv files etc.
    Shifting everything onto a network drive makes it a much easier proposition (IMHO) and frees up space on your PC.
  12. themediaman
    themediaman
    Nov 17, 2010
    2,017
    Glasgow
    +171
    agreed..............:D
  13. TommyZ
    TommyZ
    Nov 28, 2009
    114
    +8
    Serviio is great. It can convert formats on the fly and stream to your TV so that your TV will play just about anything.
    If your TV does not have DLNA then you can still do it via a DVD player etc. as long as it has DLNA.
