Streaming Audio thru Denon AVR4306
Discussion in 'AV Receivers & Amplifiers' started by shropsboy, Apr 28, 2007.
Tags:
  1. shropsboy
    shropsboy
    Dec 27, 2004
    Huddersfield
    +10
    Apologies if this is posted in the wrong place, but can someone give me some idea how I can stream internet radio from the laptop through the Denon amp. The only way I can think of doing this is by connecting via the headphone jack from the laptop to the amp. Is there a better way of doing this?
    The laptop is running Vista Home Premium if that is any help.
  2. andykn
    andykn
    Feb 13, 2006
    4,733
    103
    +232
    I tried doing just that from my Dell and the level was very quiet - you should really be using a Line Out jack rather than headphones.
    Unless someone makes some sort of impedance matching device.
  3. True-Blue
    True-Blue
    Jun 28, 2006
    2,476
    63
    Watching Everton
    +177
    i thought you could use an ethernet connection for this ??
    Haven't got a 4306, but I thought that was the case
  4. andykn
    andykn
    Feb 13, 2006
    4,733
    103
    +232
    You can stream audio thats on a PC through the Denon.
    What I suspect the OP wants to do is stream Internet radio through the PC then through the Denon.
    I tried to do this with Pandora, which you can't run directly from the Denon as its browser based
  5. charliecossie
    charliecossie
    Aug 10, 2002
    359
    28
    Frankfurt
    +26
    Surely, one of the main features of the 4306 is that it can connect directly to the net. Why stream the radio from a PC?
  6. andykn
    andykn
    Feb 13, 2006
    4,733
    103
    +232
    As I explained, one reason is to stream stuff from Pandora.com.
  7. io4
    io4
    Jun 22, 2006
    42
    11
    Madrid
    Why don't use the Internet Radio option of your denon?
