Streamer for Apple Music.
bealehere
Hi Everyone.
Looking to get a streamer. I currently have an Denon X4500H but for the life of me it just won’t stream Apple Music for more than about 1 song then just simply won’t connect. So looking to try something else.
I have another room and an older Nad C352 and some other sets of speakers I can’t use that I have packed away as I didn’t want to let it go.
What streamer can I use to make use of the Apple Music, if any at all that will play through Wi-Fi and not Bluetooth so I can keep the lossless quality.
Rich
xmb
As you Denon already supports AirPlay it should work! Have you checked you have the latest firmware installed on the Denon? Have you tried using a Ethernet cable to the Denon from your Router to check for Wi-Fi issues?
No point buying another device if it is a problem with your Router or Wi-Fi.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
