Not sure if this this is correct forum if not apologies anc can somebody suggest a better place to post.
I have upgraded the firmware on the Humax Foxsat box (v4 Bundle - highly recommended) and now wish to stream recorded programmes (realise I cannot do HD as they are encrypted) to Samsung DLNA enabled TV; there is a Windows 7 machine9 (with Windows Media Player [WMP] setup as DLNA Media Server) on the same network.
Has anybody managed to stream ( and transcode) the .ts files directly from FoxSat to Samsung TV (without static intermediate conversion)? I know people have streamed to a PS3 (which does seem to work but presumably sports bigger file format range) Would TVersity be of any help?
Paul
- The Samsung AllShare module can see files on the FoxSat via Twonky and can play music and photos but not the video File format not supported.
- I can open and play the .ts files from FoxSat directly without conversion (locally or via network) in WMP12 running on the Windows 7 machine . However if I choose the WMP12 Play to Function and select the Samsung TV (visible on the network) it does not playa and get error. WMP12 is meant to transcode on the fly but is obviously not doing.
- If I play a wmv file I can send it to the TV using the same functionality in WMP12 so streaming does work ( all permissions are set ok)
- If I use FFCoder (recommended) to convert the .ts file ( or group of file) to a MPEG4 format using default settings (H.264 and AAC) I can then play file on Windows 7 WMP12 and stream to the Samsung TV.
- I have tried using VLC media player on Windows 7 machine with great disappointment. In the transcoding it produced MPEG4 format that the sound did not play in WMP12 or the conversion was very blocky and also could not work out how to stream to the TV (it does have reserved IP Address) . In theory VLC should have been able to transcode and stream and it may be that I am using all the wrong settings but did look at what the Samsung should support and tried many of the options but I had no luck and a few crashes. (http://i397.photobucket.com/albums/pp60/samsung_hd_tech/dddlna.jpg)
- It has been suggested that it may be to transcode and stream in real time with some tools ( ? FFmpeg ) but this looks command based and from the deveopement site not even sure what platform it runs on.
Paul
