K I'm really a newb to this stuff, so basically, i set up my dg820, with 5.1, speakers being SS-B1000 rears, Sony SS-F6000 mains, and Sony SS-CN5000 center, sounds great, but when turned to loud volumes, it goes into protection mode, or even at 45 sometimes. Basically I heard 2 versions, one power supple is insufficient, Im basically using a plug that like, adds 4 other blocks to a socket, with a surge protector plugged into that, holding my LCD TV ps3, and the surround is connected via the plug hub thing. Someone told me it could be this, or it could be i need, banana plugs? If its the plug issue, will a buying a power bar solve this instead of using that plug hub thing? or would it be the same scenario, not sure if power bars give more voltage and what not.
Also, for speaker settings, I got them all set to small, and my front crossover is set at 80 as i dont have a sub and want them to output abit of base. Not sure if this is relevant or not.
