STRDB940 or AX620 for £150????
Discussion in 'AV Receivers & Amplifiers' started by BigAde, Jul 29, 2002.
  1. BigAde
    BigAde
    Jul 22, 2002
    1,026
    East Sussex
    +30
    Okay, I need some advice from you experts on this one...
    I've been offered (second-hand) either a Yamaha DSP-AX620 or a Sony STRDB940, each for £150. Both are in good condition, have little use and are working well.
    Not bothered at all about the RDS bit of the Sony, and I will use the pre-out option from the amp for the main speakers to be powered by my valve hi-fi amp. So I'm really only worried about the quality of DD/DTS decoding and quality of amplification to centre and rears.
    I presently use a DSP-E492 with the DD decoding being done by the onboard decoder of the LG-3350E DVD player.
    Any advice would be much appreciated!
  2. Jenz
    Jenz
    Personally I preferred the acoustics of the Yam. I also found the Sony to be a pig to set up. My brother auditioned both and we went for the Yam.
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    I'll sell you my Yam 620 for £100 - 3 months old, boxed with manual.
  4. BigAde
    BigAde
    Jul 22, 2002
    1,026
    East Sussex
    +30
    Thanks for the offer - not sure I'm close enough to Berkshire to make it worth while! Thanks anyway...
