STRDA1200ES problems !! help required
Discussion in 'AV Receivers & Amplifiers' started by Spysmys, Sep 18, 2007.
  1. Spysmys
    Spysmys
    Aug 31, 2007
    47
    11
    My first post, love the site and thanks for all the info.
    I bought a STRDA1200ES about 2 weeks ago, connected the SKY HD box via s-video and DVD via s-video, Components to 42" Samsung HD plasma. All works great except for one problem:
    Every now and then the picture goes slightly fuzzy, even the on screen menu is fuzzy. The edges goes all shaky and blurry. To get rid of this I need to power everything down and switch them all back on again. The picture does this for both SKY and DVD, audio is fine.
    Any one come across this or have any suggestions.
    Help will be much appreciated.
    Spysmys
  2. nonsoloinglese
    nonsoloinglese
    May 9, 2006
    1,954
    Kent
    +168
    Just a quick question, why are you connecting your SKY HD box via S-Video and not HDMI/Component?
  3. Ross-P
    Ross-P
    Mar 16, 2005
    400
    UK
    +25
    I would 2nd this ! :thumbsup:
    If you connect via HDMI to your amp it will give your amp a pure digital signal therefore a better picture, this alone might remedy the problem.
  4. Spysmys
    Spysmys
    Aug 31, 2007
    47
    11
    Sorry Sorry Sorry, I'm being very blonde...... I have a SKY+, not SKY HD, it's just a typo.
  5. Spysmys
    Spysmys
    Aug 31, 2007
    47
    11
    No One ?
    Does anyone thing changing cables will work ?
