Strda-3200es & Kef 1005 Subwoofer
S
spanna2000
I have the Sony STRDA-3200ES & Kef 5.1 speaker package 1005. The speaker package came with a subwoofer but I can't get any sound out of it.
The subwoofer produces sound if I connect line level input to the input, i.e. from my mp3 player headphone socket to the left input.
I've checked my speaker cabling and if I connect the amplifier end of the sub speaker cable to my MP3 player I get sound this way too so wiring is ruled out. Phew, at least I don't need to get the floor up again to change the cables.
If I connect the sub to the sub pre out on my 3200ES I get nothing at all, nothing from the test noise, nothing from the autocalibration. The sub is at default -30db volume, do I need to increase that? Even if I do it doesn't help. Do I need to have the receiver in any particular decode/input mode?
Is my amp faulty or is there some complex setup I have missed? Should I expect the 3200 pre amp out to driver the kef sub if the kef sub says it needs "line level" input? Is there a way I can test the amp with another speaker without damaging the speaker or the amp?
The receiver was purchased from superfi so packing and returning is not going to be fun - I hope this is a nubie error in the setup.
Hope you can help.
Regards
S
spanna2000
on a similar theme - should i expect the set up menus to work over HDMI? I can only get the OSD if I use component out. I am assuming this is a limitation of the HDMI implementation. The video passthrough works fine.
Mr_P
Hope you can help.
Regards
Try setting your speakers to "small" in the 3200es speaker set up menu. That may just do the trick. Then try autocalibration again.
