Strange ?
Discussion in 'Digital TV & Video Players & Recorders' started by 1smith7, Jul 21, 2004.
Tags:
  1. 1smith7
    1smith7
    Here's the story. I currently have SKY in my living room but also have a 25 metre cable running up to my bedroom which is then plugged into The SkyLink that I have and gives me lovely reception. The problem is when i connect the cable w/sky link to my VCR i cannot record from the sky source because the picture is so bad, but i can record my terrestrial channels perfectly . Do I need a signal booster, then a problem arises i'm not sure if my sky link will work if there is a signal booster attached
    What do ye think ? :lease:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    First thing to check is the channel tuning on the VCR, it sounds like auto-tuning hasn't locked onto the digibox RF channel output, there should be a manual adjustment both to select the channel frequency and to fine tune an existing one.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Bet ya the RF output of the VCR is exactly the same as the digibox ;)
    Default for digiboxes is CH68. See what the VCR is set to. Even if it's not the same, change it and retune the TV as necessary.
    You don't need a 'signal booster'.
    Hope this helps.
    A. Dork
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I'm sure I'm telling you what you already know, but the RF output could never be described as 'quality', I'd never recommend it for anything more than a bedroom portable myself. Trouble is it's so damn useful and easy to implement. You probably also know it's mono only, no nicam modulation in a sky box. It shouldn't be unwatchably bad on anything 20" or less though, so likely you have a clash of channels, or imprecise tuning.
