Strange widescreen problem/qustion
Discussion in 'LCD & LED LCD TVs Forum' started by Gortz, Dec 25, 2004.
Tags:
  1. Gortz
    Gortz
    So I got me a Sharp LC32GA3E and the picture really is outstanding. Anyways I have this weird thing going on with widescreen movies, if I watch one in 1:85 format so it fills the whole screen it seems to jerk a little when the camera pans across things etc. Could that be the refresh rate? What should I be using? I have either 60hz or 59hz. The problem isnt there if it's in 2:35 widescreen but it's not full screen in that format.
    I'm using the DVI input and playing the movies thru my computer's DVD drive (its a high spec machine so I wouldn't have thought it would be responsible.
    Any suggestions?
    Thanks!
  2. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    If it happens on Region 2 movies but not Region 1 movies then it is almost certainly due to the PC outputting a 50Hz source at 60Hz - the stuttering being the point where the extra frame is inserted.
    Phil
  3. Gortz
    Gortz
    Ah right, well is is happening on region 2 movies yeah. I haven't got a region 1 movie to try it with I don't think. I'll have a look.
    Is there any way I can rectify it?
    If thats the case why would it only be noticable on the 1:85 aspect movies?
