Question Strange sound from the speakers Marantz NR1403
Ganeshi83
I connected my TCL Roku TV to the Marantz NR1403 through HDMI ARC and whenever I am playing a movie over netflix, there is a weird alienish sound coming out of the speakers. No problem when connected through optical. Problem with the TV or the receiver?
Dolus
Is the sound also coming from the TV as well as the speakers, which if out of sync can cause the odd effect you are hearing.
dante01
If using ARC then the TV's own speakers wouldn't be in use. ARC doesn't allow both the TV's speakers and the AV receiver to handle the audio simultaneously.
Ganeshi83
I have attached a recording of the sound that is coming out. The sound is coming out of only the speakers connected to the AVR.
  • Recording.mp3
dante01
There are other reports of similar weird sounds in association with DD+ formatted audio accessed via ARC, usually while being accessed via an LG TV. There's no reported fix for this issue though, but maybe consider contacting your TVs manufacturer?
There's a workaround. You can access audio via the TV's optical output as opposed to using ARC. This will however result in you being unable to get DD+ and you'd need to settle for regular Dolby Digital instead. This isn't really an issue unless wanting to output Atmos from a TV, but your AV receiver isn't Atmos capable anyway.
Ganeshi83
Its a TCL Roku TV. For now I have hooked up the AVR using optical. Just wanted to make good use of the built in features and reduce a wire :).
AdrianC
Switch your output to anything except DD+ on your Roku. Do this under tv audio setting. I had the exact same problem and this fixed it.
