Strange Sound error on sky
Discussion in 'Sky Digital TV Forum' started by boyimace, Feb 8, 2009.
  1. boyimace
    boyimace
    Jul 3, 2005
    442
    +5
    When forwarding/reversing or going into the menu (with background music turned off) the sound rather than being quiet it sounds like when you don't have a channel tuned in.
    Is anyone else experiencing this? I've switched sources to DVD and no problem there,
    My kit:
    Sky +
    Onkyo HTX 22HD
    Samsung LCD
    No changes in kit.
    Anyone got a clue?
  2. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Not knowing how you have all your kit connected, no.
    I presume you are taking the audio from the Sky box to the Onkyo. How? Optical?
    Do you get the same "noise" if you use the sound from the TV, not via the Onkyo?
    Neil
  3. boyimace
    boyimace
    Jul 3, 2005
    442
    +5
    Hey Neil,
    thanks for the effort, I've found out how to fix it, had to enter installers menu and rebuild sky+, worked and now is fine.
    cheers anyway
