Strange Sky Installation...
Discussion in 'Sky Digital TV Forum' started by Multiplex, Sep 2, 2004.
  1. Multiplex
    Multiplex
    I'm moving into a new house...and was wondering if there would be any drawbacks in installing Sky+ in the shed...and then using video senders to transmit the signal to my living room?
    It would save on lots of cable routing and would make one less box under the TV!
    I've never used video senders before...would the picture and sound be unacceptable? Maybe this is a dumb idea....but i'd like to know :)
    Simon.
  2. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    I have a pair of One for All Video Senders going from my Sky box downstairs to the bedroom upstairs. They also have an LED that you stick onto the sky box (or whatever) to control it. Works like a dream. PQ is as good as downstairs (from what I can see).
    Not sure about going from a garden shed..Depends on the distance. But you wont be able to transmit Dolby Digital from your Sky + box using these senders. Maybe dig up the garden and lay a length of cable ;)
  3. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Don't forget that the picture would be composite-only. Fine for a small TV in a bedroom, but get to 28" and above and the flaws start to show. Would also loose widescreen switching, if that's an issue for you.
  4. Roohster
    Roohster
    Jul 1, 2004
    4,246
    7
    Derbyshire
    +4,678
    Another consideration is damp/condensation.
    Unless your shed is well insulated, this may cause problems - I certainly wouldn't want to store ANY a/v equipment in my shed!
  5. Fernsehman
    Fernsehman
    My shed gets boiling hot in summer and freezing cold in winter. Not good for reliability. And the ants and spiders get into everything.... !
  6. Roohster
    Roohster
    Jul 1, 2004
    4,246
    7
    Derbyshire
    +4,678
    ... I think all the signs are saying "dont put SKY in yer shed!"
  7. luggsie
    luggsie
    Aug 18, 2004
    199
    South East
    +8
    I have used a video link to get to living room from SKY box in the bedroom for more than a year. Mostly fine unless:
    1. someone walks in front of the antenna, it then drops the picture
    2. the microwave oven next door can produce white lines on the picture (oddly, tends to happen at the same time each day, ie. meal times).
    3. anyone using WiFi on their computer could cause interference, though I dont think I have this problem (hard to tell without a WiFi laptop)
    3. The IR reverse link can get interference too and make the SKY box do very strainge things because of random signals coming from the IR emitter.
    so check for a clear radio channel before installing
    luggsie
  8. luggsie
    luggsie
    Aug 18, 2004
    199
    South East
    +8
    Forgot to mention range of RF links. These are fine for line of sight. Mine works on the slant through a standard wood floor with joists etc. plus about 10 m range but that's about its limit. It is totally blocked by one 9" brick wall at this range. So depending how far the shed is from the house you may need to install new windows in the house and shed, lined up with the antennas.
    luggsie
