Hi all,
I hope someone is willing and able to help me. I´ve searched a lot about my problems but no result.
I´ll try to describe it.
- Turned on the box from stand-by (clock showing)
- Got "Pb03" in display
- Tried pressing "OK" and got blank display and then "Er01"
- Pressing "OK" (or any button for that matter) and display showing "00--" where "--" is flasing
- After a few seconds "Er09" shows in display
- Pressing any key shows "Er01" again and then it repeat it self as above
I have tried having it without powercord for over 30 min and plug it in again but no result other than above.
Got this problem once before but then it was enough just disconnecting the power and put it back. ¨
I live ine Sweden and not sure if we get upgrade on the air
Thankfull for any help!
