Strange Problem with TV Remote and Pronto Edit
johndon
I'm using TVRemote from www.padwin.com and prontoedit to create a CCF to run on an iPAQ 2210.
I've created a CCF for Sky+ (v1 box) and the problem I've got is that I can't get Backup and the 5 & 9 keys to work if I try to learn them. I've also downloaded a couple of CCF's from RemoteCentral and have exactly the same problem with them.
Funny thing is I can get the buttons to work with an ordinary Sky digibox, just not with the Sky+ box.
Any Ideas?
John
A
ailean
I've had a few problems with certain remotes or buttons (got the same h2210/TVremote setup), I've not got sky thou so can't check that. One thing I did find with some stuff, if you setup Nevo for the device it may work perfectly.
Not sure why TVremote fails thou, you could also try learning it in the native TVremote mode rather then Pronto emu. Certainly from my experience it appears to be more of a software fault then the iPaq hardware.
Not sure if pdawin are still developing it thou.
65-inch LG C1 Review coming soon to AVForums
