Strange problem with Sony Wega TV
Discussion in 'Satellite TV, Sky TV & FreeSat' started by WhyAyeMan, Jul 4, 2002.
  1. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,073
    Newcastle
    +292
    I have a Sony Wega 32" widescreen TV with an integrated digital tuner and have a strange problem with it. I can be watching a channel (normally seems to BBC) and all of a sudden the picture will go off, accompanied by two fairly loud beeps. You then have to turn the TV over to another channel and then back again to get it back on.
    Does anyone know why this happens?
  2. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    I'm not too sure but it sounds like your t.v. has a definate problem the best thing to do is to call sony and get an engy. sent out. Unless anyone one here knows how to fix it.
    Sounds like a fault though.
    Hope it helps
    Spunky
  3. Squirrel God
    Squirrel God
    I was going to say that if this only happened when watching digital then it might be your signal strength dipping or problems with your coax cables or something like that.
    But the two beeps are of concern .... have you checked at the back of manual to see if these are error codes that have an attached meaning?
  4. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,073
    Newcastle
    +292
    Thanx for the replies. I suspected it could be a fault with the TV, but I can only remember it happenning on BBC (not ITV or Sky) so the you could be onto something with the signal strength. I shall have a look in the manual tonight to see if I can find out what the beeps mean.
    Thanks again.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    BBCi
    Call 0870 600 1717 and ask for a fix from Sony
    TV Software fix!
    Waiting for mine - spoke to someone helpfull yesterday
  6. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,073
    Newcastle
    +292
    MartinImber, thank you very much indeed sir, you are a saint!
    I will do that! :D
    Thanks again!
