Strange problem with my new setup...
Discussion in 'AV Receivers & Amplifiers' started by t0by, Feb 23, 2005.
  1. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Hi folks
    I got my new components yesterday (PW7, AVR-2805, DVD-2900) but I am having problems with a continuous buzzing sound through all of my speakers (all 5.1 of them) when everything is turned on.
    I have:
    Sky to Denon 2805 via JS Labs RGB>YUV
    Denon DVD-2900 to Denon AVR-2805 via component
    Denon AVR-2805 to PW7 via component
    Kef eggs and Kef sub connected direct to AVR-2805
    The buzzing is constant but, by a process of elimination, I have found that it stops completely if I disconnect the sub audio connection. I have tested the sub on a friend's system and it functions perfectly so I am sure that its not at fault.
    Its all a bit weird and I don't have the expertise to work out what is wrong.
    Any ideas... :lease:
    Thanks.
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Hi.
    Do a search on earth loops or ground loops. I suspect this is the problem.
    I bet it is somewhere with the sky connection!
