Logo Hater
I have a JVC LCD TV Model number LT-20DA6SK.
It has developed the strangest problem, which is occuring much more frequently.
I have it connected to a Panasonic DVD Recorder and a Sky Box, both connected through scart leads which automatically change it to the appropriate AV channel when switched on. However a few months ago I tried to watch a programme which was recorded on the Hard Drive of the recorder, I could see the picture but could not hear it. I stopped the recording and it obviously went back to showing the TV channel which was selected on the recorder, which I could both hear and see.
I thought no more about this as I then had to go out and the next time I tried it it was fine. This has happened a few time recently and when it does, if I turn the Sky box on there is picture but no sound. Each time the TV channel being fed through the recorder is viewable with sound and picture, suggesting that all the pins in the scart lead are functioning correctly. No matter how many times I turn the recorder on or off, this does not change. But I cannot hear any recordings either from disc or the hard drive.
I have found by experimentation the solution seems to be to unplug the TV from the electricity supply for a short while, then plug it back in, then everything is back to normal and working fine. Obviously as this is happening more and more frequently it is becoming annoying.
Has anyone got any ideas what is happening and a solution if one exists please.
Most of the time it is fine and functions as it should, but I cannot understand this at all.
