Strange Problem with DVD Disk ??
Discussion in 'Movie Forum' started by cosmic023, Feb 19, 2003.
  1. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi All,
    I've been collecting DVD's now for over 3 years, and all my disks are in good condition.
    But i do have a copy of "The Terminator" when it first came out on DVD.
    So on Sunday i fancied having a blast of "The Terminator", so much for that........skip..skip...jump..jump...........!!
    After taking the disk out to have a look, it's got patches of moisture INSIDE the DISK ??
    What has caused this, and is there anything i can do....apart from buying a new copy ??
    Cosmic023
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    This is a known problem and has been covered before.
    Have a look here
    regards Hans
  3. nathan_silly
    nathan_silly
    Disc rot. Nowt you can do, except contact the retailer who you purchased to from and ask for a replacement (or sending a letter to MGM)
    Another alternative is asking a mate to make a copy of his original Terminator SE-make an exact copy. Ok it's piracy, but you've got the an original- it went bad because of manufacturing faults, therefore you've every right for a working version , by whatever means.
  4. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    ******, I had a quick look at my disc and guess what? Knackered:mad: :mad: :confused:
    what other discs are prone to rot, as I may as well get it over and done with in one go.
  5. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Just had to try bolex as thats the camera of choice for outdoor adventure films, did I get censored?
  6. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi All,
    Thanks for the info. We pay good money for these items, and all we get is crap !!
    Do they still do this, or was it a early problem with the manufacturing of the DVD disks ??
    Thankfully i don't think i've got any duff disks, but i'll go through my collection and check it out !!!
    Cosmic023
  7. nathan_silly
    nathan_silly
    What Terminator version have you got?
    Mine is the Canadian R1 Terminator SE.
  8. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Its a well known problem that affects alot of Technicolor (also Nimbus) made R2 dvds - See this link at dvdforums technicolor dodgy dvds
    The following are known to have the problem
    Terminator - MGM
    Silence of the Lambs - MGM
    Rocky Boxset - MGM
    Midnight Cowboy - MGM
    The Night of the Hunter - MGM
    No way out - MGM
    The Manchurian Candidate - MGM
    Never Say Never Again - MGM
    Thunderball - MGM
    Casino Royale - MGM
    The Good the Bad & the Ugly (2nd pressing) - MGM
    First Great Train Robbery - MGM
    Annie Hall - MGM
    Some like it Hot - MGM
    Topsy-Turvy - Fox/Pathe
    The Girl on the Bridge - Fox/Pathe
    Yellow Submarine - Fox/Pathe
    Space 1999 vol 3 - Carlton
    Dinosaur Collector's Edition (disk #1) - BVE
    Lady & the Tramp 2 - BVE
    Oliver & Company - BVE
    Rescuers Down Under - BVE
  9. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi Nathan,
    I have a copy of the first "Terminator" UK SE DVD, it was a gold disk, i suppose these were the ones that were faulty ??
    I also have a Canadian R1 copy of "T2-Ultimate Edition" in a metal box !!
    Acording to the list posted by Captineyecatch, "Terminator" is the only one listed here i have in my collection.
    Cosmic023
  10. nathan_silly
    nathan_silly
    I've had two discs with disc rot- R1 canadian ver of Chicken Run, and R1 canadian ver of License to Kill. Worked fine for a year, then pixellates at the layer change, then eventual lockup.
    I'm in the process of backing up my DVD's- looking around for a DVD writer, then software to copy Dual Layer 9 GB's with exact picture & sound quality of the original.
    I can do 4.7 GB's, no problems- but these don't suffer from DVD rot.
    I have the Metal box of T2 (R1, canadian) I've heard single disc version (dual layer, dual sided) has problems than the 2 x dual layered version.
  11. nwgarratt
    nwgarratt
    May 5, 2002
    27,155
    +3,023
    The discs that are affected include MGM or pathe discs that are manufactured by Technicolor. The only one I had affected was The Terminator. If you clean the disc, I washed it with a tiny bit of soap and a lint free cloth. It worked and now the disc plays fine and that was about six months ago
    Also, anyone with the R1 of Blade II, check your discs. The case of my copy has made a disc crack at the centre. Luckily, it was the extras disc and not the film. It will be the disc on the tray.
    I know a couple of other people with the same problem.
  12. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi All,
    I had an e-mail from MGM last night, and they said they know about the fault !!
    So all i need to do is send it back to a freepost address, and they will return me a brand new copy of "The Terminator"
    Look forward to it !!
    Cosmic023
    PS: I've also read that "T3: Rise of the machines" is due out soon ?? Theatre debut out sometime in June ??
  13. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    I had the same problem with my Terminator and Silence of the Lambs UKR2. let me guess your terminator strted jumping at the shootout scene in the policestation and get's stuck after arnie leaves and Sgt. Kyle Reese and Sarah Connor drive away in the car. If that's the case do not dispair!!!
    here's the lesson for today:lesson:
    take your discs (u should see that moisture on the xtrasdisc as well) and wash'em...yes wash'em in lukewarm water with a bit of washingupliquid. I didit and the disc worked again
    :lesson: lesson over
    HTH
  14. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi Lux,
    Thanks for the tips mate..........I'll try that but the rot covers 2/3rds of the disk, and it's pretty much gone :( and plays the first 4 chapters, and then it's pretty much unplayable from the middle of the 4th chapter !!
    So i'll give it a go later, but i think i'll end up sending it back and get a new copy !!
    Cosmic023
