Strange problem audigy 2 - pioneer vsx d912
Discussion in 'AV Receivers & Amplifiers' started by lil old me, Sep 12, 2004.
Tags:
  1. lil old me
    lil old me
    Nov 2, 2003
    90
    I just bought an audigy 2 and have had my pioneer amp for some time. I am connecting the audigy using 3 3.5mm - phono connectors into the 7.1 channel input on the back of my amp. When i first connected my amp I couldn't hear anything. So i played with the cables and accidently one of the phono connectors touched one of the outputs on my amp. I could immediatly hear the music I was playing from my pc.
    It now appears that as long as one of the phono connectors, -ve or +ve is touching an output on my amp/dvd/ntl box/tv/ then sound will play from my computer. If not then nothing happens.
    Another unusual problem is that 'touching' the phono means exactly that, I do not connect it into the female end on my amp, I have to just touch itto the outer metal part of the femal input. If i plug it in properly then it will not work.
    Can anyone help me? Either to find out why this is happening or a possible solution.
    PS
    One thing to note is that the 3.5mm - phono connectors do not run all the way to the amp....they connect half way to a JVC phono extention from dixons. Might this be making any difference?
