MIghtyG
Got a bit of an odd problem with my card, an EVGA GTX1070 FTW. I have recently got myself a 4K TV in the room with my PC, so for the odd game I want to play with controller from the sofa I decided to run a short HDMI to the TV, simple.
The TV is a 4K HRD ready TV, so thought I would switch on all the bells and whistles with my PC. I set the PC to only display on the TV and turned on HDR and set the res to 4K.
Then while playing on the TV the signal goes black for a second or two, then comes back for a few min, then goes again, then comes back for some amount of time (anything from 1-15min) then black, then back, then black etc.
I figured maybe its the HDMI cable, not up to snuff. So cut the resolution in half and turned off HDR. Still had the same problem.
For tits and pickles, I decided to use a displayport to HDMI adaptor and try one of the display port connections on my card rather than the HDMI. That was about 2-3 days ago and I havent had a signal drop out since, for some reason on Hitman I still cant get HDR working but I am playing away happily at 4K 60Hz using a display port to HDMI adaptor and the same HDMI cable as before.
Any ideas? A bad HDMI port on the card?
