Strange plasma fault?
Discussion in 'Plasma TVs Forum' started by Redeye UK, Dec 10, 2004.
  1. Redeye UK
    Redeye UK
    Dec 2, 2004
    142
    +16
    A 2 year old Fujitsu PDS4242 has recently developed a strange fault. On start up the picture is fine from all sources. After about 30 mins, what I can only describe as horizontal jitter becomes evident at the bottom of the screen. This gradually gets worse and travels further up the screen until after about an hour and a half it becomes unwatchable.
    Maybe I'm being paranoid but I'm sure the fans aren't cycling like they used to, they are quietly blowing but I'm sure they used to intermittently 'boost'?
    I know it's a long shot but does anyone have any first hand experience of this problem?
    or
    Does anyone know how overheating affects a screen's picture?
    Thanks for reading.
  2. jaguar
    jaguar
    Nov 17, 2004
    186
    Electronic components can break down in such a way that their behavior is temperature depended.
    Apparently some components in your plasma stop working correctly if they warm up.
    Changes that it will go away on it's own are slim.
    Not much more to do then to offer the screen for repair.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Fujitsu come with 2yr warranty so get it repaired...... sounds like it could be the AVM unit over heating
