Strange picture effect on DVD25
Discussion in 'Blu-ray & DVD Players & Recorders' started by pullman, Sep 3, 2003.
  1. pullman
    pullman
    Hi all,
    I have upgraded my Harman Kardon DVD 25 with the Apache hack that gives region freedom and PAL prog scan.
    Since then (at least I think so) I have been noticing that when the image gets really white, such as during explosions or for instance during the movie "Pi" in which there are several very light sequences, a strange black "zigzag" pattern appears in the top right corner, stretching towards the other side of the screen.
    Has anybody else experienced this? What is it? Can it be cured? Is it really the DVD or is it my Tosh 32ZD26, which has been strange since day 1?
    I hope you can help,
    pullman
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    It's probably the Tosh. Pop over to the Telly forum on this site to find out about all the woes of CRT telly ownership. :(
  3. Sharring
    Sharring
    Jun 15, 2002
    72
    2
    11
    Bolton
    Not something Ive noticed on my DVD25 (I have the Apache firmware) so maybe your TV is at fault.
    One thing i have noticed is the angle icon appears briefly on some discs, but this has been mentioned elsewhere in these forums and I dont think its anything to do with the apache mod.
  4. JFDI
    JFDI
    Not happening with my HK/Panny plasma combination either.
    Hope you get it sorted.
  5. pullman
    pullman
    Thanks everyone. It could very well be my Tosh, which has been acting strangely since I got it. In the midst of trying to have it exchanged so hopefully that will sort it out.
    Thanks again
    pullman
  6. Poissony
    Poissony
    Jul 18, 2000
    188
    28
    UK
    +24
    pullman, I had the same problem and had the Tosh Gamecube modification done by Toshiba (see this thread)but the problem remained. This solved it though. Try this:
    Adjust the contrast and brightness of the DVD25 via the ezmenu to about -8 (or you pause it on a scene where the distortion occurs and adjust until the distortion stops) and then compensate for this using your Tosh TV contrast, brightness settings and the distortion will hopefully disappear.
  7. Hodger
    Hodger
    Had exactly the same symptom with my HK25 and Hitachi plasma.
    I changed to PAL60 in the DVD menu and all is well!
    Not sure if you will get the same results with your set-up but hope it helps.
    Rob
