Strange PE30 Aspect Ratio Question
Discussion in 'Plasma TVs Forum' started by bobbles, Jul 12, 2004.
  1. bobbles
    bobbles
    I have a rather odd problem
    On certain channels the aspect ratio automatically changes. I have switched it from panasonic auto to 16:9 but it still does it!
    and on certain dvds WIDE appears on the display every 10 minutes or so, again it is not on Panasonic Auto
    Does this seem normal?
  2. bobbles
    bobbles
    Is there a hidden menu (or one that I can not find) to turn off the automatic aspect ratio switching?
    I would have thought it only did this on the panasonic auto setting, but this does not appear to be the case with mine
  3. dempsey
    dempsey
    There is a problem with these panels mainly on freeview and sky digital with certain channels. Its a two part problem, one is with the signal being sent by sky on these channels and "junk" on the part of the signal which controls aspect and the second issue is that the plasma identifies this as the aspect command and changes rapidly.
    There is no fix at this stage unfortunately but as far as I am aware Panasonic's development people are working with sky to try and resolve it.
    Hope this helps
    D
  4. bobbles
    bobbles
    cheers
    It does seem odd though. You would have thought that if it was not on panasonic auto it would leave it alone.
    Watching sky sports news is an absolute nightmare
    I have emailed panasonic. Interesting to hear what they say.
  5. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    How have you connected Sky+ to your PE30? I took delivery of my 42PE30 today and I'm still trying to work out the best connectivity and picture settings.
  6. bobbles
    bobbles
    tv scart on sky+ direct to tv rgb AV1
  7. bobbles
    bobbles
    my dvdr is connected to av2 s-vhs
    xbox is connected to av4 rgb
    dvd connected via component leads av4
  8. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    I was a little worried earlier because the default screen settings are really awful for a Sky signal. Had a play around and improved it a lot. My wife almost killed me when I first switched the thing on. Would be interested in knowing what your picture settings are.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    You could try cutting the switch oin on the scart so TV gets no aspect signal at all.
  10. Rob20
    Rob20
    Jul 3, 2004
    3,188
    +722
    My dad's Sony FQ75 has the same problem. When watchinjg certain dvd's it switches constantly between 4:3 and 16:9. It's extremely annoying. :mad:
