Strange Pace Twin Problem
Discussion in 'Digital TV & Video Players & Recorders' started by Shady Deal, Dec 2, 2004.
Tags:
  1. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Up to now I have always been happy with the twin, but recently it sometimes looses ITV1 and Channel 4. The only way to get them back is to scan for channels again.
    Anyone else??
  2. Dave H
    Dave H
    Aug 20, 2000
    4,393
    Lots of different places!
    +144
    Try the mod in the post "Pace heres a strange thing" it cured mine.
  3. Darwin
    Darwin
    Jan 11, 2005
    5
    Abingdon, Oxfordshire
    I'm having a similar problem with the ITV channels (Multiplex 2).
    It seems that if both receivers are showing a channel within this group then it will not display either channel and will not record.
    If I want to record a Multiplex 2 channel (http://www.dtg.org.uk/retailer/dtt_channels.html#mux2) then I have to ensure that the TV1 channel is not a Multiplex2 channel.
    I have spoken with Pace and they think it is a hardware fault with the tuner - Unfortunately it is out of warranty!!
    I would be interested in trying the mod but can't find the posting for "Pace heres a strange thing" despite seaching all forums with a combination of the words.
    Could you give me a bit more info Dave?
  4. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
  5. Dave H
    Dave H
    Aug 20, 2000
    4,393
    +144
    sorry its my fault I got the title wrong :rolleyes:
    but my Pace twin has been fine since I did the mod :)
    I want to try the hard drive mod next because I keep filling my hard drive up now its working :rotfl:
    Dave.
  6. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    I, too, have added the extra earthing and it does seem to have improved the thing's stability.
  7. Darwin
    Darwin
    Jan 11, 2005
    5
    Thanks chaps. My soldering iron is heating up as a type. Fingers crossed
  8. Darwin
    Darwin
    Jan 11, 2005
    5
    Have now added the extra earthing and........
    It worked!!!!!!! :clap:
    The problem was always repeatable in the evenings and I have run a few tests, the error rate doesn't waver and I can simultaneously watch and record MUX2 channels. I will wait to see if I have to power cycle the box any less.
    Many thanks to you all.
  9. Dave H
    Dave H
    Aug 20, 2000
    4,393
    +144
    Glad it worked for you :thumbsup:
    Dave.
  10. junkpuppets
    junkpuppets
    Jul 5, 2004
    44
    cambs
    +4
    so does this improve the failed recordings bug?i've had enough of power cycling and loosing recordings and was thinking of getting a Thomson DHD4000 hoping they are more stable
  11. Darwin
    Darwin
    Jan 11, 2005
    5
    It has certainly made my unit a lot more stable (and easier to live with)since I made the modification. I used to have to power cycle it about 3-4 times a week. I haven't had to do it since but it's only been a week.
    The way to see if you had the same problem as I did is to put both TV1 and TV2 on to a MUX 2 channel and see if the bit error rate starts to jump around.
    If it does and the unit is out of warranty I would definately give it a try.
    Good Luck
  12. Rambles
    Rambles
    Jul 14, 2004
    8,302
    UK
    +1,281
    What sort of wire did you use?
  13. Dave H
    Dave H
    Aug 20, 2000
    4,393
    +144
    I used some wire I had lying around the garage Iam not sure what gauge it was but it was about 3 or 4 mm thick.
    Dave.
  14. Rambles
    Rambles
    Jul 14, 2004
    8,302
    UK
    +1,281
    Thanks for replying, both me and my Dad have a Pace Twin, and he has a soldering iron so we are going to have a go.....
    Sorry to be dim, but is it just like speaker wire? Or can I cut up an old cable, like an s-video cable or something?
  15. Darwin
    Darwin
    Jan 11, 2005
    5
    It needs to be reasonably thick so that it has very low resistance. The cheap speaker wire isn't really thick enough but if you have some of the more expensive stuff it should do. I wouldn't use the S-Video cable as this will probably be a screened cable and not suitable. I would say you should be looking for something with a core bigger than 2mm squared. I used some old thickish car wiring (the sought you find to wire up the live connection on a car stereo)
    One tip, when soldering to the chassis you may need to use clean a small area so that the solder will take to it. (The tuner cans are fine as they are tinned) If you use abrasive paper or wire wool make sure the metal dust doesn't fall onto the circuit board. Likewise make sure none of the solder falls onto the board either.
    I hope it solves your problems as well as it has done mine.
