Strange noise from TV - Help !!
Discussion in 'General TV Discussions Forum' started by Adam Min, Feb 15, 2005.
  1. Adam Min
    Adam Min
    I've got a Philips 28PW6615 TV about 4 years or so old. Anyway when you first switch it on it has started making this vibrating noise which is pretty loud. It disppears after a a couple of minutes. Can anybody offer any advice?
    Is this the tube warming up and if so does it mean its on the way out ?
  2. Adam Min
    Adam Min
    Sorry forgot to add that picture and sound normal.
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Adam,
    Very unlikely to be the tube.
    Sometimes a component in the Power Supply or Line Timebase starts to resonate.
    If you hit the cabinet (GENTLY!), does it stop?
    Probably nothing to worry about, but it can be annoying.
