Strange Noise from new Philips
Discussion in 'General TV Discussions Forum' started by lambertcar, Aug 13, 2001.
  1. lambertcar
    lambertcar
    I have recently purchased a Philips 32PW9545C.<br />On low volume you can hear a strange noise like a vibration. It sounds like a small symbol being played. It varies with the picture and sometimes dissappears until a new scene switch on the program. Is it normal?
    John
    Apart from that cracking TV even if it is a discontinued model now.
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    There was a mild problem with internal wiring a while back, not being dressed properly and vibrating in sympathy with your audio. The cure was to get it looked at and tie up and redress the cables internally.
